Database upgrade from subsonic 4.6?
maxslug
Unread post by maxslug »
Hi Devs,
Is it possible to use a 4.6 install to seed madsonic, or do I need to start over from scratch?
Right now I get a schema issue from missing columns in my tables.
 java.sql.SQLException: Column not found: ALBUM_ARTIST
thanks!
-m
Re: Database upgrade from subsonic 4.6?
hi,
since 4.8 the upgrade should work, but i sounds like a rare migration issue. :cry:
i recommend you to start from scratch, you have clean index, new default Setting-File, new Transcoding defaults ...
maxslug
Madevil wrote:hi,
Thanks, I figured that would be the case. Is there any way to just get the user table over? I have way too many users to go and do password resets.
-m
this FAQ Articel can guide you: http://forum.madsonic.org/viewtopic.php?f=5&t=31
