Build: 4.8.3340 Beta3 Possible Bug
Posted: 12 Feb 2013, 17:51
I've installed subject version over the previous beta build. WIndows 7 enviroment.
I noticed in Settings =>> Network that if I uncheck 'automatically Configure your router...' that I get the message 'Port forwarding disabled' while at the same time I recieve the message that '<userdomainname>.subsonic.org responded successfully'.
In the previous beta version I could have the Automatic Port forward unchecked because I do have port forwarding active and working on my router.
WHile I don't think this is a big issue right now, I thought I would mention it.
