The Upload Function..
Posted: 10 Feb 2013, 07:27
by uploadsucks
Is there a way to edit the destination of the upload?
Re: The Upload Function..
Posted: 10 Feb 2013, 17:15
by GJ51
In Subsonic it used to be an editable setting on the "More" page. Now, in Madsonic the upload parameters are visible in a pop-up window accessed by clicking on the upload icon. When the window opens there is an entry box for the "Uploas to" directory, but I'm unable to edit it. I tried selecting a file to upload to see if that would enable editing of the upload directory, but it appears that editing the directory just isn't active.
I also looked in the file in the C:\Subsonic directory that holds most of the settings parameters but couldn't find it in there either, so it looks like this is a bug that need to be fixed.
Posted: 11 Feb 2013, 04:51
by uploadsucks
Good man GJ51. We need to petition the coding overlords to get this function fixed. It's integral to the whole system.
Posted: 11 Feb 2013, 09:10
by GJ51
The overlords have been made aware!
I never noticed it before as I have all my uploads done through Filezilla.
We're still in beta, so I'm sure it will get fixed.
