Accessing Madsonic database
Posted: 24 Jan 2013, 02:55
by gurutech
Just wondering if there's a way to directly access the database through a 3rd party utility, such as Crystal Reports or Business Objects. Can anyone point me towards being able to do this? Looking for something to keep me busy for this weekend, since it's gonna snow, and I may be "trapped" in my house... LOL
Re: Accessing Madsonic database
Posted: 24 Jan 2013, 06:48
hi, i used this Tool for SQL Tasks
http://www.razorsql.com/
to access your subsonic db you must shutdown your service before.
Posted: 07 Mar 2013, 05:31
by gurutech
Will def. check this out! Thanks!
Getting error "Cannot find user ADMIN".... Using the Subsonic.Data file - is that the correct one? It's under /var/subsonic/db
Posted: 14 Mar 2013, 22:38
hi,
Database File: /var/subsonic/db/subsonic.script
User: sa
no Password!
this should work!
Posted: 15 Mar 2013, 02:43
by gurutech
I've connected to the db, but I am not seeing any data. I can see table names, but that's about it.
See attachment, I have highlighted "username (pk)" on the left, but nothing shows on the right. Same for anything I highlight.
Posted: 11 Apr 2013, 10:37
by ForSSux
Hi There
click right in the right upper windowd
Apperently you can also drag en drop the table in the view in Windows
Kind Regards
Posted: 11 Dec 2017, 02:55
by frank2228
I know this post is old as hell but I am interested in trying to look at/edit the madsonic database.
Are you guys accessing your database locally? I currently have my madsonic installations on headless Ubuntu VMs and administer them remotely from my Windows machine. I am not sure how to get RazorSQL to connect remotely.
Any help is appreciated.
