Icons settings not working
muiz
Has thanked: 4 times
Icons
Unread post by muiz »
Its impossible for me to set the icons in settings - icons
I am using 4.8.3312 Beta3
bushman4
Unread post by bushman4 »
Good morning,
I upgraded to the latest beta this morning, and it appears to have broken the Icon Settings page... no matter what I check or uncheck, the icons stay the same.
The top frame does a refresh, but does not change.
I found out when I went to look at the version number in the "about" screen... it was checked off in the icon settings, but it did not appear. I unchecked it, saved settings, and rechecked it, and saved settings, but no change.
Then I tried a bunch of the other icons, and nothing seemed to happen.
Thanks,
Glenn
Re: Icons settings not working
hi, i forgot to explain the recent changes in more detail.
Since last version the top-icons for the Admin-Role are always visible.
so just create a new user without the Admin-Role and it should work.
bushman4 wrote: I found out when I went to look at the version number in the "about" screen... it was checked off in the icon settings, but it did not appear.
Glenn
VersionService check for new Version is only every 7 Days or on Service restart.
utopian
Unread post by utopian »
i've just a fresh install of the latest version and icons not working for me.. tried unchecking a few (was actually looking for the "about" icon which i have now ticked but the ones i want gone are still there and "About" is a no show
Any advice
cheers :D
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech »
You can click the "MadSonic" logo (when logged in) to view the Help/About info.
I just found this out the other day myself... :-)
utopian
gurutech wrote:You can click the "MadSonic" logo (when logged in) to view the Help/About info.
ah brilliant.. cheers for that :D logging in as a non admin does appear to show the correct icons i want...( as mentioned in the posts above..)
