Icons
Posted: 13 Jan 2013, 20:15
by muiz
Its impossible for me to set the icons in settings - icons
I am using 4.8.3312 Beta3
Icons settings not working
Posted: 15 Jan 2013, 16:48
by bushman4
Good morning,
I upgraded to the latest beta this morning, and it appears to have broken the Icon Settings page... no matter what I check or uncheck, the icons stay the same.
The top frame does a refresh, but does not change.
I found out when I went to look at the version number in the "about" screen... it was checked off in the icon settings, but it did not appear. I unchecked it, saved settings, and rechecked it, and saved settings, but no change.
Then I tried a bunch of the other icons, and nothing seemed to happen.
Thanks,
Glenn
Re: Icons settings not working
Posted: 15 Jan 2013, 17:24
hi, i forgot to explain the recent changes in more detail.
Since last version the top-icons for the Admin-Role are always visible.
so just create a new user without the Admin-Role and it should work.
Posted: 15 Jan 2013, 20:16
Glenn
VersionService check for new Version is only every 7 Days or on Service restart.
Posted: 18 Jan 2013, 13:07
by utopian
i've just a fresh install of the latest version and icons not working for me.. tried unchecking a few (was actually looking for the "about" icon which i have now ticked but the ones i want gone are still there and "About" is a no show
Any advice
cheers
Posted: 18 Jan 2013, 14:27
by gurutech
You can click the "MadSonic" logo (when logged in) to view the Help/About info.
I just found this out the other day myself...
Posted: 18 Jan 2013, 14:44
by utopian
gurutech wrote:You can click the "MadSonic" logo (when logged in) to view the Help/About info.
ah brilliant.. cheers for that
logging in as a non admin does appear to show the correct icons i want...( as mentioned in the posts above..)
