Is there a link (sourceforge or github) to download the Madsonic source code like Sindre does with Subsonic?
I have modified the TranscodingService.java to be able to download an AAC file when the user bitrate is unlimited and use a specific transcoding when the user bitrate is limited.
In Fact, in my Library there are only AAC files, and I wanted to have the same behavior as if I had mp3 files.
So, I'd like to add this modification in the next release of Madsonic... But if you are agree to add this feature in your future release, it would be greater
thinks for your great work on Subsonic !
