License not valid
lebuz
License not valid
Unread post by lebuz »
I have a lifetime license, now not valid, but when i try to satus it ok, I have madsonic in deb mode
Versión MADSONIC 7.0.10400.a6fd24b.20220120.1226 - IP address [192.168.1.24]
REST MADSONIC REST API v3.0.0, MADSONIC REST API v2.8.0, SUBSONIC REST API v1.16.0
Server jetty/9.4.44.v20210927, java 11.0.22, Linux 5.15.0-107-generic (amd64) (130,2 MB / 258,0 MB)
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:148)
at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:129)
at java.base/java.security.cert.CertPathBuilder.build(CertPathBuilder.java:297)
at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:434)
... 125 more
its update mint version, java update and try to restart madsonic service many times
Skywatcher
Re: License not valid
Unread post by Skywatcher »
Same problem here. I renewed my license and the site shows up the new expiry date, but when trying to insert it in madsonic it tells me Invalid License Key!
lebuz wrote: 27 May 2024, 11:50 I have a lifetime license, now not valid, but when i try to satus it ok, I have madsonic in deb mode
... 125 more
There may be a problem with the Java version used and the certificate root path, but this can be solved by importing the root certificates into the Java trusted store.
In order to check your account, I still need the email address you used to register with Paypal. Please send it to me via PM.
Skywatcher wrote: 27 May 2024, 12:08 Same problem here. I renewed my license and the site shows up the new expiry date, but when trying to insert it in madsonic it tells me Invalid License Key!
nunyas
Unread post by nunyas »
I'm having this issue as well this morning. I performed an OS update (ubuntu) and the Madsonic server stopped recognizing my permium key as valid. I checked the sit and it states my premium key is valid.
nunyas
I fully realize that Madsonic support needs a PM from me with my email in order to check my account. However, it seems I am unable to send PMs at this point in time because of a lack of user activity ...
nunyas
I suppose I can post some additional details:
My invalid license issue started after I performed a Ubuntu 20.04.6 OS update a couple of days ago.
Madsonic Version: 7.0.10400 (originally had the issue with 7.0.1039... upgraded to 7.0.10400 in hopes of it correcting the issue)
Java (from Madsonic logs): Java: 11.0.23, OS: Linux
Using the key I had before the upgrade I get the following message:
Invalid Madsonic license key!
Next I used the "Lost the license key? Send it again." option. Received the email from Madsonic with the license key (the same one I've been using for years). Put the key in, and received the "Invalid Madsonic license key!" message again.
Next I tried the "Problems with your license key? Check your license." option. Putting my email address in on that paged returns:
Madsonic Premium license status
License valid: true
License email: <redacted>
License expiry date: 2025-04-03
lebuz
I have a solution import ssl cert madsoic.org to java root cert
you need download cert of https://madosnic.org with firefox chrome or any do you see in google how to download cert
when you have cert
Convert the root certificate to DER format
go to download pathc and open terminal
openssl x509 -in madsonic-org.pem -inform pem -out ca.der -outform der
at this moment you need import certificate to root cacert need the path of java home, this for mi
sudo update-alternatives --config java
this is the result
/usr/lib/jvm/java-11-openjdk-amd64/bin/java
now import cert key
sudo keytool -importcert -alias startssl -keystore /usr/lib/jvm/java-1.11.0-openjdk-amd64/lib/security/cacerts -storepass changeit -file ca.der
now you put license and enjoy
These users thanked the author lebuz for the post:
Skywatcher
nunyas
lebuz wrote: 15 Jun 2024, 10:30 I have a solution import ssl cert madsoic.org to java root cert
you need download cert of https://madsonic.org with firefox chrome or any do you see in google how to download cer
when you have cert
got to download path and open terminal:
at this moment you need import certificate to root cacert need the path of java home, for me:
this is the result:
now import cert key:
sweet cheeses! that did it! thank you SO MUCH!
Skywatcher
Holy moly! That did it! Didn't even have to reinsert the license key.
You, sir, are a hero!
