Hello, I just installed madsonic 7 in a debian 11 VM, there are lots of things not working :
media scanner : I can see the artists list if I go in the index section, but nothing in artist hub, discover your music. on my phone I use the ultrasonic app (android) but the artist list stays empty (works fine with subsonic server)
I got java errors in the logs, but can't find how to correct them :
[2022-03-02 04:43:41,945] ERROR SuggestionFuzzyService - Failed to close suggestion index.
java.lang.NullPointerException
at org.madsonic.suggestion.SuggestionFuzzyService.stopIndexing(SuggestionFuzzyService.java:134)
at org.madsonic.service.MediaScannerService.doFullScanLibrary(MediaScannerService.java:440)
at org.madsonic.service.MediaScannerService.access$200(MediaScannerService.java:65)
at org.madsonic.service.MediaScannerService$4.run(MediaScannerService.java:217)
when logged with a user that have admin rights : settings not working, home not working, show statistic, now playing, tag radio says to scan library first (done that 5 times), playlists not found (the playlists path is correct), upload
that makes a lot
Madsonic 7
cyberbabacool
- Been thanked: 0
Jump to
- ↳ Info / Announcements
- ↳ Voting Polls
- ↳ Madsonic Client
- ↳ Support
- ↳ Feature Requests
- ↳ Madsonic Node
- ↳ Support
- ↳ Madsonic Server
- ↳ Info
- ↳ Support
- ↳ Plugins & Addons
- ↳ Docker
- ↳ UnRAID
- ↳ FreeBSD
- ↳ FreeNAS
- ↳ Synology
- ↳ QNAP
- ↳ OpenMediaVault
- ↳ Netgear
- ↳ Asustor
- ↳ MusicBee
- ↳ Tomahawk
- ↳ XBMC
- ↳ Clementine
- ↳ KODI
- General
- ↳ Info
- ↳ Announcements
- ↳ Voting Polls
- ↳ General
- ↳ Development
- ↳ Development Voting Polls
- ↳ Client 6.x
- ↳ Info
- ↳ Support
- ↳ Bug Reports
- ↳ Solved Requests
- ↳ Server 5.x
- ↳ Support 5.x
- ↳ Bug Reports 5.x
- ↳ Feature Requests 5.x
- ↳ Server 6.x
- ↳ Info
- ↳ Support 6.x
- ↳ Bug Reports 6.x
- ↳ Feature Requests 6.x
- ↳ Solved Requests
- ↳ Node 6.x
- ↳ Info
- ↳ Support
- ↳ Download
- ↳ Madsonic 6.x
- ↳ Madsonic Transcoding
- ↳ Player / Tools / Themes
- ↳ Scripts
- ↳ Off Topic
