Hello
I've jut installalled 20190425_madsonic-6.2 on my Ubuntu 20.04 box. I'm running it alongside subsonic 6.1.6 , both at different ports subsonic at 4040 and Madsonic at 4045
Subsonic is working just fine
madsonic seems to be working, i can see it locally on my cellphone remote. But I cannot get to the web interface to set it up. I don't even get a 503 error. Nothing, as if the web-server wasn't up and running. Ive tried stopping subsonic to see if maybe jetty was having issues with both,. i don't get anything
here's the last few lines from /var/madsonic_sh.log and var/madsonic.log
Jun 10, 2020 11:27:23 AM org.springframework.jdbc.datasource.DriverManagerDataSource setDriverClassName
INFO: Loaded JDBC driver: org.hsqldb.jdbcDriver
Jun 10, 2020 11:27:24 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from class path resource [org/springframework/jdbc/support/sql-error-codes.xml]
Jun 10, 2020 11:27:24 AM org.springframework.jdbc.support.SQLErrorCodesFactory <init>
INFO: SQLErrorCodes loaded: [DB2, Derby, H2, HSQL, Informix, MS-SQL, MySQL, Oracle, PostgreSQL, Sybase]
2020-06-10 11:27:27.685:INFO:/:Initializing Spring FrameworkServlet 'madsonic'
2020-06-10 11:27:28.544:INFO:oejs.AbstractConnector:Started @0.0.0.0:4045
Madsonic running on: http://localhost:4045/
and
root@fausto-Desktop:/var/madsonic# cat madsonic.log
[2020-06-10 11:27:23,940] WARN HsqlDaoHelper - Checking database schema ...
[2020-06-10 11:27:24,951] INFO HsqlDaoHelper - Done checking database schema.
[2020-06-10 11:27:24,952] INFO HsqlDaoHelper - Checking HSQLDB version: 2.3.4
[2020-06-10 11:27:25,145] INFO SettingsService - Java: 1.8.0_252, OS: Linux
[2020-06-10 11:27:25,148] INFO SettingsService - write transcode path to property file: /var/madsonic/transcode
[2020-06-10 11:27:25,155] INFO SettingsService - ffmpeg: ffmpeg version N-48652-ga087764847-static https://johnvansickle.com/ffmpeg/ (25.04.2019) Copyright (c) 2000-2019 the FFmpeg developers
[2020-06-10 11:27:25,155] INFO SettingsService - Madsonic scanMode: NATIVE
[2020-06-10 11:27:25,222] INFO MediaScannerService - Automatic index scan: every 1 day(s)
[2020-06-10 11:27:25,222] INFO MediaScannerService - NEXT: Thu Jun 11 03:00:00 EDT 2020
[2020-06-10 11:27:25,256] INFO UPnPService - Checking UPnP service...
[2020-06-10 11:27:25,325] INFO PodcastService - Automatic Podcast scan: every 24 hour(s)
[2020-06-10 11:27:25,325] INFO PodcastService - NEXT: Wed Jun 10 11:32:25 EDT 2020
[2020-06-10 11:27:25,440] INFO UPnPService - Disabling UPnP/DLNA media server
[2020-06-10 11:27:25,449] INFO UPnPService - Checking UPnP service - Done!
[2020-06-10 11:27:35,285] INFO NetworkService - Deleted port mapping for port 80
Can anyone lend a hand here?
Tim
Lake Hawatha NJ
New Install of madsonic-6.2 on Ubuntu 20.04 no Web Interface
coacharnold
- Been thanked: 1 time
Re: New Install of madsonic-6.2 on Ubuntu 20.04 no Web Interface
Edit: (06/16/2020)
I downgraded from Ubuntu 20.04 to Ubuntu 18.04 and most of my problems with Madsonic disappeared. I suggest you do the same.
Preface:
I'm running Madsonic 5.0 so this may or may not be of use.
I just upgraded my server software from Ubuntu 16.04 with kernel 3.14.0-44 to Ubuntu 20.04 with the latest kernel and openjdk-8.
When I restored my backup of my Madsonic software two things didn't work properly:
1. When I made changes to the "/etc/default/madsonic" file and entered sudo service madsonic restart to make the changes take effect, the service still made the web page available on the original port number instead of the one I entered into the configuration file.
The solution for this was a reboot of the server hardware.
2. Whenever I rebooted the server hardware the Madsonic service would start, then fail. I'd have to type sudo service madsonic start to manually get it to run. From then on it would run stable until the next reboot.
To solve this I made a script that would automatically execute the sudo service madsonic start command after the boot process.
Preface:
