Internet Radio
3Dscrewer
Internet Radio
Post by 3Dscrewer »
Hi ....
I can't find the internet Radio. I can add the adress but don't find a button or something else. The Link I am using also in Subsonic and it is working. of course I'm using the payed version.
TIA
These users thanked the author 3Dscrewer for the post:
WasagaGeek
WasagaGeek
Re: Internet Radio
Post by WasagaGeek »
Same thing here, added my Internet Radio station in the setting but I will be dammed if I can find out how to access it?? lol
If you end up finding out how, please let me know and I will do the same.
Cheers
Hogan
WasagaGeek
Re: Internet Radio
I found it, it does not seem to show up when logged in as a administrator, log on as a regular user and you will see it right at the bottom of the menu. I attached a screen shot.
J_T_W
Been thanked: 5 times
Re: Internet Radio
Post by J_T_W »
I can't answer for Madsonic as I moved off of it a long while back when it was clear that it was abandoned. Both Subsonic and Airsonic Advanced will display any internet radio on the left-side pane menu, along with the alphabetical lists.
It is a pretty lateral move off of Madsonic to Airsonic Advanced https://github.com/airsonic-advanced/airsonic-advanced - It is in active development with frequent snapshot updates https://github.com/airsonic-advanced/airsonic-advanced/releases . Minimal effort for installation (Java installed, then a command line shortcut to the war file - upgrades even easier with just a fast war file change).
If you're looking to move off the Subsonic family of servers altogether, you can also check out Navidrome https://www.navidrome.org/ . The primary focus at the moment for Navidrome is a more modern develpment language and a move off of java. There is a focus on keeping the API modern for app support, although there is a rudimentary UI.
