Search not working
plablo09
Search not working
Post by plablo09 »
I have a clean 7.x install Everything works fine except for the search service. I get empty results for everything. I checked the logs and found:
SuggestionSpellService Failed to close spell index.
uggestionFuzzyService Failed to close suggestion index.
After that every search returns (on the log file)
ERROR SuggestionFuzzyService failed while searching for "whatever"
Any help is appreciated
darren
Re: Search not working
Post by darren »
Is anyone working on this issue? I tried search using v6.2.9084.8df1ddd in the web interface and I still get no results.
I also tried using the REST interface
http://my.ip.address.here:4040/rest/sea ... uery=chris
And I get the following result
<subsonic-response xmlns="http://subsonic.org/restapi" status="ok" version="1.14.0" type="subsonic">
<searchResult3/>
</subsonic-response>
Any chance this will be fixed?
Thanks.
