I recently switched back to the firefox browser and have found I can no longer select -> add to playlist. I can select the songs from an album but once I hit the add to playlist drop down nothing happens. I just opened an instance up in Chrome and found adding songs isn't an issue.
I've disabled all extensions for my madsonic tab to ensure it's not that. Is anybody else encountering this issue?
Can't Add to Playlists With FireFox (67.0.4 64-bit)
Re: Can't Add to Playlists With FireFox (67.0.4 64-bit)
I can't reproduce the Problem with my setup.
Can you please use the following Support Header: viewtopic.php?f=2&t=1520
Greetings Kae
Greetings Kae
Its working here too, I tried with very old and very updated browsers and with all the adblockers/cookie blockers/referer spoofers you can imagine 8-)
Please include some screenshots, so we can take a look where you are and what you're trying to do.
