Organize by folder structure greyed out. How to disable?
Unread post by Matt Zornig » 13 May 2019, 20:24
 VERSION:      MADSONIC 7.0.10390.a6fd24b.20190510.1010
 SERVER:       jetty/9.4.z-SNAPSHOT, java 1.8.0_131, Windows 7 6.1.7601 (amd64) (150.5 MB / 390.0 MB)
 OS:           WINDOWS 7 64Bit
 SYSTEM:       SERVER
 INSTALLER:    WINDOWS
 JAVA:         java version "1.8.0_211" Java(TM) SE Runtime Environment (build 1.8.0_211-b12) Java HotSpot(TM) 64-Bit Server VM (build 25.211-b12, mixed mode)
 BROWSER:      WaterFox 56 MacOS10.12.6
 DESCRIPTION:  Organize by folder structure greyed out and activated. How to disable?
 REPRODUCIBLE: YES
I found several entries in search, but not any solution,
How to disable Organize by folder structure setting in Media Folders Menu.
after fresh install, first check.
I have installed from scratch, no settings was changed, logged in as admin.
Re: Organize by folder structure greyed out. How to disable?
Unread post by Matt Zornig » 02 Jul 2019, 15:16
nobody?
