v7: Need new premium license? [EDIT2: Upgrading Java fixed it]
garyo
Has thanked: 8 times
Been thanked: 17 times
Unread post by garyo »
I have a paid-up Madsonic premium license (on subscription). I just updated to v7 (smooth & totally painless), and notice it's not enabled for Premium. Went to enter my license key, and it says it's invalid. Does V7 need a new license? I had the server resend my key, but it's the same one.
garyo
Re: v7: Need new premium license?
Aha, I bet this error from the log is helpful:
[2019-04-29 10:35:04,824] WARN SettingsService - Failed to validate license.
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed
: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to
requested target
        at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
        at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949)
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302)
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296)
        at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1509)
        at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216)
        at sun.security.ssl.Handshaker.processLoop(Handshaker.java:979)
        at sun.security.ssl.Handshaker.process_record(Handshaker.java:914)
        at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062)
        at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375)
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403)
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387)
        at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFac
tory.java:436)
        at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:384)
        at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
        at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:374)
        at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:393)
        at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
        at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
        at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
        at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
        at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:72)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:221)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:165)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:140)
        at org.madsonic.service.SettingsService.validateLicense(SettingsService.java:3099)
        at org.madsonic.service.SettingsService$1.run(SettingsService.java:3122)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387)
        at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292)
        at sun.security.validator.Validator.validate(Validator.java:260)
        at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324)
        at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229)
        at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
        at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1491)
        ... 30 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
        at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
        at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
 Missing cert files perhaps?
 My madsonic instance has full access to the public Internet, FYI.
garyo
Re: v7: Need new premium license? [EDIT: failed to validate lic]
Anything on this? Are other v7 testers seeing properly activated Premium?
KaeTuuN
Has thanked: 5 times
Been thanked: 18 times
Unread post by KaeTuuN »
I have no issues verifying my license.
Greetings Kae
PS: Next time please use the "Bug Header" so it is easier for everyone to help you.
mtnkodiak
Unread post by mtnkodiak »
I also have no problem activating my premium upon v7 upgrade. I have seen the dreaded PKIX path building error before, when doing some SSL work at a previous job... I seem to recall it was a configuration issue on my end, but it was a while ago.
Please look here for a possible solution: viewtopic.php?f=75&t=2649#p8355
garyo
garyo
Hmm, upgrading Java in my jail is going to take some work. The jail is quite old now, Freebsd 9 if I remember. And yes, all the cacerts files on that machine are old.
garyo
Re: v7: Need new premium license? [EDIT2: had to update Java, working now]
I created a whole new Freenas jail with a more recent FreeBSD, installed latest Java (openjdk 12) and Madsonic 7, copied over my database from backup, and now my Premium license works again. Thanks!
These users thanked the author garyo for the post:
