Failed to validate Madsonic key
pawel_w
Unread post by pawel_w »
 VERSION:     6.1.8700.3847bea
 SERVLET:
 SERVER:      FreeNAS-11.1-U6.3
 OS:           FreeBSD 11.1-STABLE (FreeNAS.amd64) #0 r321665+6bdfda58b62(HEAD): Thu Dec 20 14:27:36 EST 2018
 SYSTEM:       SERVER
 INSTALLER:     DOCKER
 JAVA:
 BROWSER:
 CLIENT:
 DESCRIPTION:  CRASH when adding licence key
 REPRODUCIBLE: YES
I use Madsonic for few months already. It is running on freenas as a plugin. I have used this for few month already so i decided to buy a licence. Unfortunately i am not able to add licence key to modsonic. After adding credential i received in email to madsonic server i got error :
I try to search for solution but no luck. In log file I fond
[2019-04-24 13:45:36,404] INFO SonosService - No Sonos controller found
[2019-04-24 13:45:38,010] WARN NetworkService - No UPnP router found.
[2019-04-24 13:45:40,772] DEBUG RESTController - supported MADSONIC REST version: 2.5.0
[2019-04-24 13:45:41,006] DEBUG RESTController - supported SUBSONIC REST version: 1.14.0
[2019-04-24 13:45:42,979] INFO BootstrapVerificationFilter - Servlet container: jetty/8.y.z-SNAPSHOT
[2019-04-24 13:46:43,650] DEBUG VersionService - Latest Version Info is outdated.
[2019-04-24 13:46:43,650] DEBUG VersionService - Check for Updates ...
[2019-04-24 13:46:43,655] DEBUG VersionService - http://madsonic.org/version.html
[2019-04-24 13:46:43,913] DEBUG VersionService - Resolved latest Madsonic final version to: 5.1.5260
[2019-04-24 13:46:43,913] DEBUG VersionService - Resolved latest Madsonic beta version to: 6.2.9082
[2019-04-24 13:46:43,913] DEBUG VersionService - Resolved latest Madsonic alpha version to: 7.0.10360
[2019-04-24 13:47:51,841] DEBUG StreamController - Wrote 196608 bytes of 196608 requested
[2019-04-24 13:49:14,162] WARN SettingsService - Failed to validate Madsonic key.
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
        at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1904)
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:279)
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:273)
        at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1446)
        at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:209)
        at sun.security.ssl.Handshaker.processLoop(Handshaker.java:901)
        at sun.security.ssl.Handshaker.process_record(Handshaker.java:837)
        at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1023)
        at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1332)
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1359)
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1343)
        at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:394)
        at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:353)
        at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:141)
        at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:353)
        at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:380)
        at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
        at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184)
        at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88)
        at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
        at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:71)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:220)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:164)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:139)
        at org.madsonic.service.SettingsService.isLicenseKeyValid(SettingsService.java:1314)
        at org.madsonic.validator.PremiumSettingsValidator.validate(PremiumSettingsValidator.java:43)
        at org.springframework.validation.ValidationUtils.invokeValidator(ValidationUtils.java:83)
        at org.springframework.validation.ValidationUtils.invokeValidator(ValidationUtils.java:55)
        at org.springframework.web.servlet.mvc.BaseCommandController.bindAndValidate(BaseCommandController.java:398)
        at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:266)
        at org.madsonic.controller.PremiumSettingsController.handleRequestInternal(PremiumSettingsController.java:62)
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:385)
        at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292)
        at sun.security.validator.Validator.validate(Validator.java:260)
        at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:326)
        at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:231)
        at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:126)
        at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1428)
        ... 97 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:196)
        at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:268)
        at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:380)
        ... 103 more
I was trying to found out what is missing but i have not found anything in jail where madsonic is installed. ( /mnt/volume1/jails/madsonic_1/ )
Can anybody point what is missing and what should i add to modsonic or to server itself ?
Re: Failed to validate Madsonic key
The error message:
This is a common error message reported by the Java Virtual Machine. This is caused when the Java environment does not have information about the HTTPS server to verify that it is a valid website.
Possible causes of this issue:
If the Java version running on your machine is not up to date, hence the cacert that is included with your old Java version does not trust the latest Certificate Authorities. Ensure you are running the latest Java version (for example oracle java 1.8.0.201.b9).
You can check if your certificate is already in the truststore by running the following command:
keytool -list -keystore "%JAVA_HOME%/jre/lib/security/cacerts"
you should find this entry:
letsencryptisrgx1 [jdk], 19.05.2017, trustedCertEntry,
Certificate fingerprint (SHA1): CA:BD:2A:79:A1:07:6A:31:F2:1D:25:36:35:CB:03:9D:43:29:A5:E8
pawel_w
Thanks for Your reply.
I spend some time to investigate and try to solve it but no luck still.
I found those java certificates folder in the filesystem
root@madsonic_1:/ # find / -name cacerts
/usr/pbi/madsonic-amd64/openjdk7/jre/lib/security/cacerts
/usr/local/openjdk8-jre/lib/security/cacerts
/usr/local/openjdk8/jre/lib/security/cacerts
so i checked for letsencryptisrgx1 [jdk] in those cacerts files and found in each ot above. i.e
keytool -list -keystore /usr/pbi/madsonic-amd64/openjdk7/jre/lib/security/cacerts -alias "letsencryptisrgx1 [jdk]"
Enter keystore password:
letsencryptisrgx1 [jdk], May 13, 2019, trustedCertEntry,
It looks that madsonic uses internal java , because in log file i see
[2019-05-13 17:24:31,069] WARN HsqlDaoHelper - Checking database schema ...
[2019-05-13 17:24:32,537] INFO HsqlDaoHelper - Done checking database schema.
[2019-05-13 17:24:32,538] INFO HsqlDaoHelper - Checking HSQLDB version: 2.3.4
[2019-05-13 17:24:32,863] INFO SettingsService - [b]Java: 1.7.0_76, OS[/b]: FreeBSD
[2019-05-13 17:24:32,887] DEBUG VersionService - Resolved local Madsonic version to: 6.1.8700.3847bea
Can I anyhow check which java is used by madsonic ?
Unfortunately after a license key entering i still see in log file error WARN SettingsService - Failed to validate Madsonic key.
[2019-05-13 17:29:17,849] WARN SettingsService - Failed to validate Madsonic key.
        ... 97 more
        ... 103 more
These users thanked the author pawel_w for the post:
it looks you have more than one java version in your docker instance installed,
check your JAVA_HOME environment to switch to Java 8.
send you via PM a link to an updated 6.1 version.
pawel_w
Thank You for help. After pointing Java 8 in JAVA_HOME and removing others it works.
thechez
Been thanked: 9 times
Unread post by thechez »
My QNAP server is doing the same thing by not retaining the license information. I am running JDK8 1.8.172.
I can't even download v7 on the site as I am getting errors.
[6/21/19 8:12 AM] INFO SubsonicRESTRequestParameterProcessingFilter REST emulator access for client 'android' has expired.
[6/21/19 8:13 AM] INFO SubsonicRESTRequestParameterProcessingFilter REST emulator access for client 'android' has expired.
[6/21/19 8:14 AM] INFO SubsonicRESTRequestParameterProcessingFilter REST emulator access for client 'android' has expired.
Any ideas?
