However, I don't see any differences from version 6 except for the new Madsonic avatar
Thanks.
I understand.Madsonic wrote: ↑26 Apr 2019, 13:45 Hi there,
The main differences are under the hood, many libraries have been updated to run technically with all current system environments.
Support for
- Java 11
- Sonos 10
- Tomcat 9
- Jetty 9
- Lucene 8
You can find more details here:
https://www.madsonic.org/pages/compare.jsp
https://www.madsonic.org/pages/changelog.jsp
I like the idea of getting rewarded, get colorful presents or even gift packs :-)zzzonedotnet wrote: ↑02 May 2019, 18:14 However as an end user, I would have liked a visible or audible reward for having upgraded. [...] Therefore, the "tester" should be rewarded with some new feature that makes the process "feel" worthwhile in my opinion.
As well asNew ID3: add custom ID-tag reading/searching
New ID3: add multitag support for genre
New ID3: add multitag support for mood
New SCAN: settings to ignore symbolic links
New SCAN: settings to ignore files/folders during scan
New SEARCH: Apache Lucene 8.0.0 implementation (better search capabilities)
New SEARCH: improved search results
New GUI: option to show multivalues (genre, moods)
New GUI: use embedded cover art
New GUI: individual sorting on tables
New SCAN: improved folder scanning
Internal upgrades are mostly ...erm... internal and won't show any fancy banner/icons/stars aka new working menu-items.New DLNA: new experimental implementation in courtesy of Allen Petersen
New SCROLLBAR: refactor implementation
Bugfix PLAYQUEUE: fix lost snyc after rerangement
Bugfix SYSTEM: fix exception without internet connectivity
Bugfix THEME: fix browser issues
