[Server 6.2.9082] Tomcat war doesn't start
KaeTuuN
Has thanked: 5 times
Been thanked: 18 times
Unread post by KaeTuuN »
 VERSION:      MADSONIC 6.2 | BUILD: 9082
 SERVLET:      TOMCAT 9.0.19
 SERVER:       CPU: Core i3-6100 | ARCH: x64 | MEMORY: 16GB
 OS:           Ubuntu 18.04 LTS Server
 SYSTEM:       SERVER
 INSTALLER:    TOMCAT WAR
 JAVA:         OpenJDK Runtime Environment (build 11.0.2+9-Ubuntu-3ubuntu118.04.3)
 DESCRIPTION:  CRASH ON START
 REPRODUCIBLE: YES
If I try to start the WAR Container my Tomcat log says:
23-Apr-2019 15:49:48.948 SCHWERWIEGEND [http-nio-8080-exec-2] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
23-Apr-2019 15:49:48.949 SCHWERWIEGEND [http-nio-8080-exec-2] org.apache.catalina.core.StandardContext.startInternal Context [/madsonic] startup failed due to previous errors
"SCHWERWIEGEND" means "FATAL ERROR".
I tried to find "the appropriate container log file", but there are no Logfiles from the madsonic Container. Can anyone help me?
Greetings Kae
These users thanked the author KaeTuuN for the post:
KaeTuuN
Re: [Server 6.2.9082] Tomcat war doesn't start
So now there is a deb Package. I tested it on a fresh virtual machine. Installed openJDK 11 und installed the deb Package. Installation throws no Errors, but i want to access Madsonic via http://<VM-IP>:4040 I get an Error:
HTTP ERROR: 503
Problem accessing /. Reason:
    Service Unavailable
Complete Madsonic Log is attached.
Greetings Kae
madosnic_sh.log
(60.21 KiB) Downloaded 236 times
You have made a configuration that does not work together.
Madsonic 6.x based on Java 7/8 and don't work with Java 11 or higher.
Madsonic 7.x is prepared to work with Java 7/8/11/13.
Tomcat 9 can run with Java 8 and Java 11.
In your case, try to start Tomcat with Java 8 or use Madsonic 7.x
KaeTuuN
Ahhhh.... good to know! :)
So I will try Madsonic 7 instead! :)
Greetings Kae
KaeTuuN
Well... I think I'm blind... Where the hell can I download Madsonic 7? oO
Greetings Kae
