Madsonic premium URL is not working
Madsonic Server 6.x
zzzonedotnet
Has thanked: 8 times
Been thanked: 13 times
Unread post by zzzonedotnet » 18 Oct 2018, 11:11
I cannot connect to my madsonic domain today (***.madsonic.org). I can connect to Madsonic over my network using the IP address.
Could this be the end of Madsonic?
Here is the error:
HTTP Status 500 - Request processing failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: c:\backend/db/madsonic-backend.log
type Exception report
message Request processing failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: c:\backend/db/madsonic-backend.log
description The server encountered an internal error that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: c:\backend/db/madsonic-backend.log
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:963)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:842)
javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:827)
javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
root cause
org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80)
org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:575)
org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:639)
org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:668)
org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:676)
org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:716)
org.madsonic.backend.dao.AbstractDao.query(AbstractDao.java:46)
org.madsonic.backend.dao.AbstractDao.queryOne(AbstractDao.java:50)
org.madsonic.backend.dao.RedirectionDao.getRedirection(RedirectionDao.java:32)
org.madsonic.backend.controller.RedirectionController.handleRequest(RedirectionController.java:59)
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:933)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:867)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:951)
root cause
org.hsqldb.jdbc.Util.sqlException(Unknown Source)
org.hsqldb.jdbc.jdbcConnection.<init>(Unknown Source)
org.hsqldb.jdbcDriver.getConnection(Unknown Source)
org.hsqldb.jdbcDriver.connect(Unknown Source)
java.sql.DriverManager.getConnection(Unknown Source)
org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:173)
org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriver(DriverManagerDataSource.java:164)
org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnectionFromDriver(AbstractDriverBasedDataSource.java:153)
org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnection(AbstractDriverBasedDataSource.java:119)
org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111)
org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77)
note The full stack trace of the root cause is available in the Apache Tomcat/8.0.32 logs.
andreasdevig
andreasdevig
Has thanked: 5 times
Re: Madsonic domain (premium) not working
Unread post by andreasdevig » 18 Oct 2018, 15:37
I get the same error. Tried uninstalling madsonic from my mp3-player and renaming the C:\madsonic\db folder to db_corrupt, but hasn't worked.
These users thanked the author andreasdevig for the post:
zzzonedotnet
zzzonedotnet
Re: Madsonic premium URL is not working
Unread post by zzzonedotnet » 19 Oct 2018, 20:27
It's working now.
These users thanked the author zzzonedotnet for the post (total 2):
Madsonicandreasdevig
zzzonedotnet
Unread post by zzzonedotnet » 01 Feb 2019, 20:00
The custom URL is down again.
andreasdevig
andreasdevig
Unread post by andreasdevig » 01 Feb 2019, 23:45
zzzonedotnet wrote:The custom URL is down again.
Mine too.
andreasdevig
Unread post by andreasdevig » 05 Feb 2019, 00:02
It's working now. Great to have it back.
zzzonedotnet
zzzonedotnet
Unread post by zzzonedotnet » 05 Feb 2019, 01:18
andreasdevig wrote:It's working now. Great to have it back.
Same here. I'm not sure if it worked but I PMed Madevil.
andreasdevig
zzzonedotnet
Unread post by zzzonedotnet » 20 Mar 2019, 12:05
My custom URL now redirects to a new website builder.
HELP.
