Madsonic service running but that's it
- Has thanked: 9 times
- Been thanked: 16 times
I attempted to reinstall the beta for 6.3 from a stable version running on Windows 10. When I installed it the control panel said that it was running but I could not open the web control. Nothing happened at all. The browser didn't even open.
So I uninstalled it and reinstalled the stable 6.2 version. Unfortunately, I got the same result. I then uninstalled that version.
I restored my registry and and then reinstalled the stable 6.2 version.
Now, the web control opens the browser but I get a 503 error and nothing displays.
What should I try next besides wiping the computer and starting over completely?
I have a Premium subscription.
Thanks.
Thanks.
Re: Madsonic service running but that's it
I had that problem, more or less, because of this bug --> http://forum.madsonic.org/viewtopic.php?f=63&t=2379
Try using the last beta version just for check :/
- These users thanked the author Tak-MK for the post:
- zzzonedotnet
Try to complete uninstall Madsonic and start from scratch:
[*] stop madsonic server
[*] uninstall madsonic
[*] delete folder c:\madsonic or /var/madsonic
[*] cleanup all Browser Caches
[*] cleanup all temp files
Info about used folders: http://beta.madsonic.org/pages/installation.jsp#general
After reinstall/restart the Madsonic service, a new database will be automatically created in the folder %MADSONIC_PATH%\db
Best rergards,
Best rergards,
- zzzonedotnet
So I installed the latest stable version of 6.2 and the web interface loads now.
It scanned my music and created a database.
The only problem now is that no cover art displays. Every cover displays as a black/blank square in the web interface in Chrome and in Firefox.
Any other thoughts?
Thanks.
Any other thoughts?
Thanks.
please retry with the latest 6.3 build, send you email with information.
- zzzonedotnet
Thank you. I will try. Did you say you were sending an email? I haven't gotten one.Madevil wrote:please retry with the latest 6.3 build, send you email with information.
WOOT.
I scrubbed the old install and all the OS and browser caches.
I installed the latest 6.3 build and was successful in that it is scanning my music (400k files) right now.
I'll let you know what happens.
- These users thanked the author zzzonedotnet for the post:
The first scan didn't work too well, got only about 25% of my music.zzzonedotnet wrote:WOOT.
But I rescanned and that seems to have done the trick.
18,977 artists
39,868 albums
1,050 genres
17 moods
372,845 songs
48 videos
10 podcasts
22 audiobooks
9572.07 GB (~ 33,847 hours)
Well. I've been testing it pretty extensively and it looks and feels good.
Best news: it's scanning tags now, I think.
Searches should be much more accurate if the music is tagged correctly.
Someone correct me if I am wrong.
How much time did it spent to scan 400k files? I have to wait a long time to scan 200k, like ten minutes or so if it's a rescan, and like an hour if it's the first scan
A full scan took several hours: honestly I didn't time it.Tak-MK wrote:How much time did it spent to scan 400k files? I have to wait a long time to scan 200k, like ten minutes or so if it's a rescan, and like an hour if it's the first scan
A rescan takes about 30 mins.
Since version 6.3, more metadata is being read out, which will take much more time for the initial scan, all other scans will consume much less time.
Go to Settings > Admin Panel and configure the scan mode to NATIVE which is much faster than the MIXED mode.
