Difficulties playing files with node
Posted: 09 Aug 2017, 03:48
VERSION: MADSONIC 6.3 | BUILD: 9560
SERVLET: JETTY
SERVER: CPU: AMD A6-3600 | ARCH: X64 | MEMORY: 5GB | HDD: 80GB
OS: CENTOS 7.3.1611 (Core)
SYSTEM: SERVER
INSTALLER: RPM
JAVA: ORACLE JDK 1.8.0_131
BROWSER: CHROME 60
CLIENT: NODE 6.2.9260
DESCRIPTION: Missing Functionality or Documentation, Tracks don't advance
REPRODUCIBLE: YES
I've tried using the nodeControl view in the API to set the node playlist and start it, however nothing is ever communicated from the server to the node, even though the node reports that it is registered. I checked with wireshark running while I was running API commands and there were absolutely no requests sent to the node from the server.
Is this an actual issue or just a case of ignorance on my part? If this functionality is not missing in code, I need some instruction on how to successfully play files from the node other than using the buttons in Settings->Nodes. I've reviewed all available documentation on the madsonic site, however I still have not been able to make this work.
