Change home page to feature Podcasts
geraldgreen
Unread post by geraldgreen »
Just found out about MadSonic just a few days ago and really liking the solution. Quick question, is there a method to substitute what's featured on homepage by default (random albums etc.) to instead show the Podcasts section ("Podcastchannels.view" on the side panel on homepage) within the main frame upon login? I currently use the Podcasts feature exclusively and could find anything in the settings and tried modifying some specific files with no success. Thanks.
These users thanked the author geraldgreen for the post:
Re: Change home page to feature Podcasts
With next build a user settings is added to select the default start page.
geraldgreen
geraldgreen
Awesome, I will be on the lookout.
