[Solved] unknown tags? where to find the origin?
I found madsonic shows me some tags, I never knew, we had in our collection.
strange and unknown tags
When I check against them in foobar2000, I don't find any GENRE tag showing up for those.
How can I find out, where madsonic is getting those tags from?
Can madsonic tell me the file and the corresponding found tags?
I realize, there is a useful "Database query" feature, which could help.
Can I use it therefore? How?
EDIT:
If found out, this happens, when there is no ID3v2.x Genre, but a ID3v1 Genre present.
(I have configured foobar2000 not show/use ID3v1 Tags, so I had to analyse the music files with a HEX or Text Viewer...)
If you want to know, which files have "wrong" TAGS or MOODS or GENRES shown in Madsonic, just create a playlist with those files, save/export it as an m3u8 playlist and load it into your favorite tag-analyzer (maybe mp3tag) (you may have to correct the paths to the files with a text editor for the exported playlist)
