[FAQ] Full Media Rescan
Initial Scan - This is the first scan of all media files found in your libary
Delta Scan - scheduled libary Scan to detect changes
Full Rescan - Full Rescan easy trick
  • go to Media folder Settings
  • Disable each Music folder (this switch the entrys to Offline)
  • Save Settings
  • Make a Full Mediascan
  • Re-enable each Music folder to rescan
  • Save Settings
  • (Clean-up Database)!?
this triggers a Full Rescan of the Metadata - You don't lost any User, Settings, Ratings
But carefully with the Database Clean-up!
This function cleanups all your old refferal to offline media so you lost the refferenc to the media files IDs!
if you Disable your mediafolders -> Save Settings -> Make a Rescan -> make Cleanup DB then the old
mediafile entrys will be deleted. This mean with the next scan, your mediafiles get new ids and you LOST
any Playlist, Rating, Starred, PlayCounts and Coments with the new media files IDs!!
Keep this in mind!
etyrnal
