network error
Madsonic Server 6.x
procyon
network error
Unread post by procyon »
When I try to connecto to my Madsonic with Android (Dsub),I get network errors, then it times out. The re no firewalls, nor proxies. Any suggestions?
Answers: 4
Has thanked: 1171 times
Been thanked: 457 times
Re: network error
if you try to connect from your browser like [url]http://<SERVER-IP>:4040[/url] does it work?
jmgant
Re: network error
Unread post by jmgant »
Yes it does. when I configured port forwarding in the software, it received an error. I opened port 4040 as well. No connections...
jmgant
Re: network error
Yes that works. I get this when configuring: Status: Failed to create port forwarding. See log for details.
Where are the logs?
