BPM stripping the bad characters
SERVER: jetty/8.y.z-SNAPSHOT, java 1.8.0_121, Linux 3.10.77 (amd64) (330.8 MB / 457.0 MB)
DESCRIPTION: see topic subject
REPRODUCIBLE: Yes.
Not much of a bug report, but some kind of feature request too.
While going through the serverlog, I saw a lot of those lines:
[2017-02-20 21:17:42,516] WARN JaudiotaggerParser - Error when parsing tags in /path/to/music/superdupermusicfile.mp3 For input string: "159 BPM"
java.lang.NumberFormatException: For input string: "159 BPM"
	at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:2043)
	at sun.misc.FloatingDecimal.parseDouble(FloatingDecimal.java:110)
	at java.lang.Double.parseDouble(Double.java:538)
	at org.madsonic.service.metadata.JaudiotaggerParser.getRawMetaData(JaudiotaggerParser.java:177)
	at org.madsonic.service.metadata.MetaDataParser.getMetaData(MetaDataParser.java:48)
	at org.madsonic.service.MediaFileService.createMediaFile(MediaFileService.java:911)
	at org.madsonic.service.MediaFileService.updateChildren(MediaFileService.java:729)
	at org.madsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:330)
	at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:418)
	at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:422)
	at org.madsonic.service.MediaScannerService.doFolderScanLibrary(MediaScannerService.java:282)
	at org.madsonic.service.MediaScannerService.access$000(MediaScannerService.java:51)
	at org.madsonic.service.MediaScannerService$3.run(MediaScannerService.java:178)
Maybe its possible to strip all the alphabetical characters and leave only the numbers, when parsing the BPM tags?
That way, the log stays smaller, is easier to read and the BPM gets its way -hopefully correctly parsed- into the database.
These users thanked the author Matt Zornig for the post:
Re: BPM stripping the bad characters
next snapshot build parse bpm values correctly if it contains "bpm" as string.
BROWSER: FF 53.x
REPRODUCIBLE: Yes
It does not work with this build.
[2018-05-03 10:08:55,841] WARN JaudiotaggerParser - Error when parsing tags in /volume1/Media/B/Big L/1994 - Lifestylez Ov Da Poor & Dangerous [TAPE+Ap]/110. Big L - Da Graveyard.mp3 For input string: "j"
java.lang.NumberFormatException: For input string: "j"
	at org.madsonic.service.metadata.JaudiotaggerParser.getRawMetaData(JaudiotaggerParser.java:201)
	at org.madsonic.service.metadata.MetaDataParser.getMetaData(MetaDataParser.java:50)
	at org.madsonic.service.MediaFileService.createMediaFile(MediaFileService.java:928)
	at org.madsonic.service.MediaFileService.updateChildren(MediaFileService.java:746)
	at org.madsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:333)
	at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:508)
	at org.madsonic.service.MediaScannerService.scanFile(MediaScannerService.java:512)
	at org.madsonic.service.MediaScannerService.doFullScanLibrary(MediaScannerService.java:361)
	at org.madsonic.service.MediaScannerService.access$200(MediaScannerService.java:62)
	at org.madsonic.service.MediaScannerService$4.run(MediaScannerService.java:209)
110. Big L - Da Graveyard.rar
The mp3 file. Password is my mailadress. Please delete after checking.
(7.36 MiB) Downloaded 488 times
