REST API: albums empty, but folders populated
Posted: 03 Feb 2017, 20:32
I'm the developer of the iOS "Subsonic" client play:Sub.
I have been investigating an issue for one of my users running a Madsonic6 server (6.1.8740.e4c6505.20161001.1002).
On this particular server, a lot of albums appear empty when loaded through the REST API (getAlbum.view)...
Album metadata is present, but no song details. For example:
Locating the same album through the folder-based API gives song data:
I have tried the above using both the Subsonic API exposed by the server (/rest/), and the Madsonic API (/rest2/) - both give the same results.
Is tere any known issues matching the above, or any things I can make the user try ?
Any and all input appreciated.
Thanks,
Michael.
"subsonic-response": {
"status": "ok",
"album": {
"artistId": "349",
"artist": "The Smiths",
"genre": "Alternative",
"id": "984",
"coverArt": "al-984",
"duration": 2792,
"songCount": 10,
"playCount": 0,
"created": "2016-04-27T19:51:33.097Z",
"name": "Meat is Murder",
"year": 1985
"type": "subsonic",
"version": "1.14.0"
}Code: Select all
"status": "ok",
"directory": {
"child": [
"suffix": "m4a",
"bitRate": 256,
"title": "The Headmaster Ritual",
"id": "18485",
"playCount": 0,
"parent": "447"
"type": "subsonic",
"version": "1.14.0"
}Is tere any known issues matching the above, or any things I can make the user try ?
Thanks,
Michael.
