Version MADSONIC 6.2.8920.912d081.20161125.0550
Server jetty/8.y.z-SNAPSHOT, java 1.8.0_111, Windows 7 6.1 Service Pack 1 (amd64) (580.3 MB / 928.0 MB)
Size: Database: 575MB, Thumbs-Cache: 117MB, LastFM-Cache: 41MB, Lucene-Cache: 29MB
Transcoder ffmpeg version N-82597-gd316b21 (21.11.2016)
Copyright (c) 2000-2016 the FFmpeg developers
It appears that lastfm queries may be causing slowness/delays in the web player. See log below. If you add up all the seconds between tracks it is not enjoyable to listen to a random selection of songs with multiple second delays. AND sometimes it never comes back causing all playback to stop until the service is restarted. Maybe allow the song to start playback before results are retrieved back??
Or it might not be Lastfm at all. But something isn't right!
is streaming RAW "CD2. Vocal Track\10 - Gushi & Raffunk - Arabian Nights.mp3"
[12/8/16 10:54 AM] DEBUG AbstractDao fn::updateMediaFile::createOrUpdateMediaFile: 17330 ms: update media_file set folder=?,type=?,override=?,format=?,data=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,mood=?,bpm=?,composer=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=?, rank=? where path=?
[12/8/16 10:54 AM] DEBUG AbstractDao fn::getTrackByName::namedQueryOne: 3357 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM] DEBUG MultiService fn::getFullArtistInfo took: 30099 ms
[12/8/16 10:54 AM] DEBUG AbstractDao fn::getTrackByName::namedQueryOne: 4554 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM] DEBUG AbstractDao fn::getTrackByName::namedQueryOne: 4740 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM] DEBUG AbstractDao fn::getTrackByName::namedQueryOne: 4453 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM] DEBUG AbstractDao fn::getTrackByName::namedQueryOne: 4886 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM] DEBUG AbstractDao fn::getTrackByName::namedQueryOne: 4536 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM] DEBUG AbstractDao fn::getTrackByName::namedQueryOne: 4985 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:54 AM] DEBUG AbstractDao fn::getTrackByName::namedQueryOne: 4342 ms: select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where title = :title and type = :type and present
[12/8/16 10:53 AM] DEBUG MultiService Starting getTopTrackArtists() id:221858 artist:Mystic Rythms Band limit:10
