Trouble Setting Up and Using New Node
Posted: 06 Nov 2016, 09:14
VERSION: MADSONIC 6.2 | BUILD: 8840
SERVLET: JETTY
SERVER: CPU: AMD A6-3600 | ARCH: X64 | MEMORY: 5GB | HDD: 1TB
OS: CENTOS 7.2
SYSTEM: SERVER
INSTALLER: RPM
JAVA: OPENJDK 1.8
BROWSER: CHROME 54
CLIENT: NODE 6.1.8740
DESCRIPTION: MULTIPLE ISSUES - SEE BELOW
REPRODUCIBLE: YES
1) After decompressing the node archive, I attempted to run madsonic-node.sh, but received an error message. It was trying to execute madsonic-node-booter.jar, however the only jar file in the directory is madsonic-node.jar. Once I edited madsonic-node.sh and pointed it to the correct file, the service was able to start.
2) I was able to create a node entry in the server and send a playlist to the node. When I clicked "Start", an error occurred on the node saying access was denied to /var/madsonic-node/transcode/ffmpeg. I had to set chmod +x on /var/madsonic-node/transcode/ffmpeg to get past this issue.
There are two main issues that I currently cannot get past:
1) After sending a playlist to the node and clicking "Start", I receive the following error message at the node (NOTE: This board complained about "off-site URLs" in this post, so I added spaces to the Java package names):
[2016-11-06 07:15:13] [INFO ] [qtp16924379-16] PlaylistController - Playing stream - (STREAM URL OMITTED) offset: 0
[2016-11-06 07:15:13] [INFO ] [/var/madsonic-node/transcode/ffmpeg InputStreamLogger] InputStreamReaderThread - (/var/madsonic-node/transcode/ffmpeg) /var/madsonic-node/transcode/ffmpeg: 1: /var/madsonic-node/transcode/ffmpeg: Syntax error: word unexpected (expecting ")")
[2016-11-06 07:15:13] [DEBUG] [qtp16924379-16] LocalAudioPlayer - Opened line com . sun . media . sound . DirectAudioDevice$DirectSDL@3bcf48
[2016-11-06 07:15:13] [DEBUG] [qtp16924379-16] PlaylistController - changeState: PLAYING
[2016-11-06 07:15:13] [DEBUG] [Thread-22] PlaylistController - changeState: EOM
[2016-11-06 07:15:13] [DEBUG] [Thread-22] LocalAudioPlayer - CLOSED line com . sun . media . sound . DirectAudioDevice$DirectSDL@3bcf48
2) Since I couldn't use the node to play from a playlist, I tried using it as a remote jukebox. However, even though the node is showing as online and enabled in the Node menu, none of the players in the Players menu will allow me to select "Node" as the player type. It is simply a grayed-out option on the page, even for the Admin user. I feel like I might be doing something wrong here, but I haven't found anything in documentation or forum that would give me a clue on this particular issue.
