Port forwarding - Java Internal Server Error
Posted: 18 Jul 2016, 01:46
I'm running the latest beta: MADSONIC 6.1.8280 on my Banana Pro with the Armbian OS (Debian Jessie based).
Everything seems to be working fine except for the Port Forwarding. I keep getting a strange Java error in the log:
I have all my router ports forwarded correctly. I was using the same setup before on Subsonic without any issues.
Does anyone have any idea whether this is an issue on my end or a bug with the latest beta?
Cheers!
WARN NetworkService - Failed to create port forwarding.
java.lang.Exception: 500 Internal Server Error: Error: ConflictInMappingEntry (HTTP response was: 500 Internal Server Error)
at org.madsonic.service.upnp.ClingRouter.addPortMappingImpl(ClingRouter.java:127)
at org.madsonic.service.upnp.ClingRouter.addPortMapping(ClingRouter.java:97)
at org.madsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:155)
at org.madsonic.service.NetworkService$Task.run(NetworkService.java:336)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)I have all my router ports forwarded correctly. I was using the same setup before on Subsonic without any issues.
Cheers!
