Deleing user...
Posted: 05 May 2016, 21:37
by lionelb
Bug when I try to delete an user (previously created with LDAP login...)
Message PreparedStatementCallback; SQL [delete from user where username=?]; java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String; nested exception is java.sql.SQLException: java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String
Java version Oracle Corporation 1.8.0_77
Operating system Windows Server 2008 R2 6.1
Server jetty/8.y.z-SNAPSHOT
Memory Used 136 of 346 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [delete from user where username=?]; java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String; nested exception is java.sql.SQLException: java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String
at org.madsonic.dao.UserDao.deleteUser(UserDao.java:156)
at org.madsonic.service.SecurityService.deleteUser(SecurityService.java:497)
at org.madsonic.controller.UserSettingsController.deleteUser(UserSettingsController.java:171)
at org.madsonic.controller.UserSettingsController.doSubmitAction(UserSettingsController.java:154)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:449)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:415)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:387)
at org.springframework.web.servlet.mvc.SimpleFormController.processFormSubmission(SimpleFormController.java:272)
at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:268)
Caused by: java.sql.SQLException: java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String
... 80 more
Caused by: org.hsqldb.HsqlException: java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String
at org.hsqldb.result.Result.newErrorResult(Unknown Source)
... 85 more
Caused by: java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String
at org.hsqldb.types.CharacterType.compare(Unknown Source)
at org.hsqldb.index.IndexAVL.compareRowNonUnique(Unknown Source)
at org.hsqldb.index.IndexAVL.findNode(Unknown Source)
at org.hsqldb.index.IndexAVL.findFirstRow(Unknown Source)
at org.hsqldb.Constraint.findFkRef(Unknown Source)
at org.hsqldb.StatementDML.performReferentialActions(Unknown Source)
at org.hsqldb.StatementDML.delete(Unknown Source)
at org.hsqldb.StatementDML.executeDeleteStatement(Unknown Source)
at org.hsqldb.StatementDML.getResult(Unknown Source)
... 88 more
