I am getting the attached out of memory error on my server:
Message PreparedStatementCallback; SQL [select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where type = ? and present and media_file.folder in (select path from music_folder where id in (select music_folder_id from user_group_access where user_group_id=? and enabled)) order by artist limit ? offset ? ]; java.lang.OutOfMemoryError: GC overhead limit exceeded; nested exception is java.sql.SQLException: java.lang.OutOfMemoryError: GC overhead limit exceeded
Java version Oracle Corporation 1.7.0_95
Operating system Linux 3.13.0-79-generic
Server jetty/8.y.z-SNAPSHOT
Memory Used 49 of 311 MB
Java OutOfMemoryError: GC overhead limit exceeded
- Attachments
outOfMemError.txt- (13.09 KiB) Downloaded 284 times
