failed to load when internet is off
Posted: 08 Feb 2016, 00:33
I've got an install of madsonic 5.1.5260 working, but i've noticed that the server won't launch when my internet connection is off.
Here is the concerned line of madonic_sh.log :*
As I understand, madsonic is looking for a fine online
so if I'm offline I cannot start the service..
I'm often running on wifi connection and the latter connects after the that madsonic tried to automatically start, so it fails according to the log above.
I'm running unbuntu 14.04, I tried to install the package libspring-beans-java, but it didn't help..
Any idea how to fix this ?
févr. 07, 2016 6:24:46 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFOS: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@753059df: startup date [Sun Feb 07 18:24:46 EST 2016]; root of context hierarchy
févr. 07, 2016 6:24:46 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFOS: Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
févr. 07, 2016 6:24:46 PM org.springframework.util.xml.SimpleSaxErrorHandler warning
AVERTISSEMENT: Ignored XML validation warning
org.xml.sax.SAXParseException; lineNumber: 7; columnNumber: 66; schema_reference.4 : Echec de la lecture du document de schéma 'http://www.springframework.org/schema/beans/spring-beans.xsd' pour les raisons suivantes : 1) Le document est introuvable ; 2) Le document n'a pas pu être lu ; 3) L'élément racine du document n'est pas <xsd:schema>.
spring-beans.xsdI'm often running on wifi connection and the latter connects after the that madsonic tried to automatically start, so it fails according to the log above.
