TODO List 6.1
TODO List 6.1
new Madsonic Todo List http://beta.madsonic.org/pages/todo.jsp#server6.1
- Been thanked: 105 times
Re: TODO List 6.1
Will there be a conversion tool for upgrading from 5.x to 6.0 or 6.1?
Or is there a way to do this manually? Basically only looking for migrating the userbase over - everything else I can do manually with minimal impact.
Re: TODO List 6.1
Thanks for the new 6.1 alpha version. Testing now. still getting use to looking for my controls on the left instead of on top. But i like what I see so far.
As always thanks for the continued development.
boco
boco
Re: TODO List 6.1
get the madsonic.script files in the DB folder ,
in this files you can find all the users config and password and things !
save all those lines delete the rest ( be careful and see which line is for what ! )
If DB are the same structure only go paste the lines into the db.view of youre madsonic server ( go to url http://exemple.net/db.view )
and press enter, now you're settings are migrated to you're DB
IF the line structure of the new db don't fit to the older, you need to do it manually ( use a text editor and build you're ownline following the new structure ! )
Insann
To only save you're user list-settings hear is a trick :gurutech wrote:Will there be a conversion tool for upgrading from 5.x to 6.0 or 6.1?
Insann
Re: TODO List 6.1
Just wondering if you will be adding 2 features that seem to be missing from previous versions.
1 - Currently unable to choose how many columns and rows of coverart to be viewed.
2 - There used to be a setting that limited the # of cover arts to be viewed per artist, and setting it to zero(0) was unlimited. I believe you have it set hard to 50.
That was a useful feature IMHO.
ty Pete
ty Pete
