Madsonic 6.1
Posted: 26 Jan 2016, 17:19
Re: Madsonic 6.1
Posted: 27 Jan 2016, 06:44
by gurutech
Can this be upgraded from 6.0, or do we have to install new?
Re: Madsonic 6.1
Posted: 27 Jan 2016, 09:28
by jake-
Hey Madevil,
will there be a stable 6.x version? ATM there are showstopper bugs that prevent using 6.0 on productive systems (
http://forum.madsonic.org/viewtopic.php?f=63&t=1592)
I'd love to see external DB support to speed up user experience but imho top prio should be to have one stable version instead of introducing new features.
ty
Re: Madsonic 6.1
Posted: 16 Feb 2016, 21:39
by Oxize
Will it be released on Synology also?
Re: Madsonic 6.1
Posted: 18 Feb 2016, 21:44
by SerpensAlatus
Synology Package would be great.
Re: Madsonic 6.1
Posted: 08 Mar 2016, 16:28
by boco
Thanks for the new version!
Re: Madsonic 6.1
Posted: 09 Mar 2016, 05:53
by gurutech
Upgraded my 6.0 beta to 6.1 and now I'm getting the dreaded 503 error.... Looks like I have to remove my database and start again....
Edit: Renamed the c:\madsonic folder, reinstalled 6.1 from scratch and ran it once. Logged in with default credentials, then stopped the service, and started copying files one at a time back from the renamed madsonic folder into the new one, restarting the service, then trying to access the site again. Found that the madsonic.data file was corrupted. After deleting this file, allowed Madsonic to recreate it from scratch, I was able to login to the site with minimal loss. Only lost my user database (which only had two users outside of "admin" and default/guest accounts.)
Had to run a media scan overnight, but the paths were already entered, as were the other settings I previously had.
Re: Madsonic 6.1
Posted: 18 Mar 2016, 16:26
by Aktarus
Where I can Download v6.1 please ??
MERCI ...and thank you for your hard work
Re: Madsonic 6.1
Posted: 31 Mar 2016, 22:31
by nmccarty
Where would it be possible to download the source for 6.1?
Re: Madsonic 6.1
Posted: 05 Apr 2016, 11:41
Aktarus wrote:Where I can Download v6.1 please ??
go to the Madsonic download page
http://beta.madsonic.org/pages/downloadAlpha.jsp
Re: Madsonic 6.1
Posted: 05 Apr 2016, 11:42
nmccarty wrote:Where would it be possible to download the source for 6.1?
online repo
https://gitlab.com/search?search=madsonic-server
Re: Madsonic 6.1
Posted: 07 Apr 2016, 15:22
by baileyb622
Are there any docs on how to build the source code? I think I have all the right dependencies but am still running into some dependency issues with mvn install.
Re: Madsonic 6.1
Posted: 07 Apr 2016, 22:26
Re: Madsonic 6.1
Posted: 23 Jun 2016, 13:20
by Jay Freeman
How often are changes pushed upstream?
I can't anything newer than 2 months ago
