Connection refused
Posted: 24 Jan 2016, 14:27
since some days, I can't acces anymore to madsonic, I got a ERR_CONNECTION_REFUSED from all web browser I tried.
I'm on debian 8 64bits with latest beta of Madsonic.(20160122_madsonic-6.0.7960.deb)
It seems that web server doesn't start but I can't find errors in logs.
here is /var/madsonic/madsonic.log (not so much lines, is it normal ?)
returns of systemctl status madsonic.service :
any ideas ?
thx
VERSION: MADSONIC 6.0 | BUILD: 7960
SERVLET:
SERVER: CPU: ICORE5 | ARCH: X64 | MEMORY: 16GB | HDD: 2TB
OS: DEBIAN 8.1
SYSTEM: SERVER
INSTALLER: DEB
JAVA: ORACLE JDK 1.8
BROWSER: FIREFOX 43
CLIENT:
DESCRIPTION: CONNECTION REFUSED
REPRODUCIBLE: YES (ALWAYS)
=========================================================================================It seems that web server doesn't start but I can't find errors in logs.
[2016-01-24 13:51:17,846] WARN HsqlDaoHelper - Checking database schema ...
[2016-01-24 13:51:19,397] INFO HsqlDaoHelper - Done checking database schema.
[2016-01-24 13:51:19,401] INFO HsqlDaoHelper - Checking HSQLDB version: 2.3.3
[2016-01-24 13:51:19,540] INFO SettingsService - Java: 1.8.0_66, OS: LinuxCode: Select all
● madsonic.service - LSB: Madsonic daemon
Loaded: loaded (/etc/init.d/madsonic)
Active: active (running) since dim. 2016-01-24 14:07:03 CET; 51s ago
Process: 16206 ExecStop=/etc/init.d/madsonic stop (code=exited, status=0/SUCCESS)
Process: 16215 ExecStart=/etc/init.d/madsonic start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/madsonic.service
└─16232 java -Xms256m -Xmx512m -Dmadsonic.home=/var/madsonic -Dmadsonic.host=0.0.0.0 -Dmadsonic.port=4040 -Dmadsonic.httpsPort=0 -Dmadsonic.contextPath=/ -Dmadsonic.defaultMusicFolder=/var/media/artists -Dmadsonic.defau...
janv. 24 14:07:03 Fozzy madsonic[16215]: Started Madsonic [PID 16232, /var/madsonic/madsonic_sh.log]
janv. 24 14:07:03 Fozzy systemd[1]: Started LSB: Madsonic daemon.thx
