7860 Media scanning failure
Posted: 13 Jan 2016, 13:57
by Magica
VERSION: MADSONIC 6.0 | BUILD: 7860
SERVLET: JETTY
SERVER: CPU: AMD 64 | ARCH: X64 | MEMORY: 8GB | HDD: 1.5TB
OS: WINDOWS 10 64bit
SYSTEM: SERVER
INSTALLER: WINDOWS
JAVA: ORACLE JDK 1.8 ( java 1.8.0_60)
BROWSER: CHROME 44
CLIENT:
DESCRIPTION: Media scanning stops and failed
REPRODUCIBLE: YES
Log from log file:
Exception in thread "MediaLibraryScanner" java.lang.NullPointerException
at org.madsonic.service.MediaScannerService.doFullScanLibrary(MediaScannerService.java:397)
at org.madsonic.service.MediaScannerService.access$200(MediaScannerService.java:51)
at org.madsonic.service.MediaScannerService$4.run(MediaScannerService.java:196)
Br
-m-
Re: 7860 Media scanning failure
Posted: 24 Jan 2016, 17:18
by Magica
I managed to solve this problem.
The problem is caused by user group access control. If group ALL didn´t have access to all media folders the scanning failed.
Older builds this worked fine (if you have restrict access rights in group ALL) but in few newer ones had this feature or is it bug.
Br
-m-
