build 7820 Issues
Posted: 04 Jan 2016, 18:02
VERSION: MADSONIC 6.0 | BUILD: 7820
SERVLET: TOMCAT
SERVER: CPU: XEON | ARCH: X64 | MEMORY: 4GB | HDD: 10TB
OS: WINDOWS 2008 R2
SYSTEM: SERVER
INSTALLER: STANDALONE
JAVA: ORACLE JDK 1.8
BROWSER: CHROME 44
CLIENT: OTHER
DESCRIPTION: CRASH ON START- no
REPRODUCIBLE: YES | NO- yes and no
=========================================================================================The Toggle PlayQueue Lock Mode button in the player has different colors, White = off, Yellow=on, Blue= Off, 2 clicks are need to toggle the sticky off.
The password reset function isnt working, I created a test user, tried to login, did the recover password, got the email, tried to use the password from the email, that didnt work, then tried the original password for the user, that also no longer worked. Had to go into admin and manually reset it. Let me know if you want more info on this.
While going to Settings> Default I get this error. It was working but then suddenly its throwing this error. I am sure a restart of Tomcat will fix it, and I will try that tonight.
EDIT: I was correct, restarting the server fixed this issue, but whos to say it wont show up again in a couple of days.
Exception java.lang.NullPointerException
Message null
Java version Oracle Corporation 1.8.0_31
Operating system Windows Server 2008 R2 6.1
Server Apache Tomcat/7.0.63
Memory Used 164 of 247 MB
Stack trace java.lang.NullPointerException
at org.madsonic.controller.PersonalSettingsController.formBackingObject(PersonalSettingsController.java:109)
at org.springframework.web.servlet.mvc.AbstractFormController.getErrorsForNewForm(AbstractFormController.java:361)
at org.springframework.web.servlet.mvc.AbstractFormController.showNewForm(AbstractFormController.java:341)
at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:281)
at org.madsonic.controller.PersonalSettingsController.handleRequestInternal(PersonalSettingsController.java:69)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:957)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:620)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:318)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
