Login Denied
Posted: 10 Dec 2015, 12:03
I edited the default "Guest" user and unchecked the ability to play files (basically I just want the guest user to be able to browse the server as an online static catalogue without being able to play, upload or download music). However, when I then try and login as Guest to test, I keep being redirected back to the login page (yes, password is correct!). I can only login as Guest if I reenable his ability to play files. Am I missing some other setting?
TIA
DDJ
TIA
DDJ
