Compilation Bug
Posted: 19 Oct 2015, 13:03
I Try to "mvn install" madsonic with 5.1 sources and i have this during the procedure
Can everyone helps for this ?
Thanks a lot
[INFO] Failed to resolve artifact.
Missing:
1) org.madsonic:madsonic-rest-api:jar:5.1
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.madsonic -DartifactId=madsonic-rest-api -Dversion=5.1 -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.madsonic -DartifactId=madsonic-rest-api -Dversion=5.1 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.madsonic:madsonic-main:war:5.1
2) org.madsonic:madsonic-rest-api:jar:5.1
1 required artifact is missing.
for artifact:
from the specified remote repositories:
com.springsource.repository.bundles.release (http://repository.springsource.com/maven/bundles/release),
java_net (http://download.java.net/maven/2/),
com.springsource.repository.bundles.external (http://repository.springsource.com/maven/bundles/external),
teleal (http://teleal.org/m2),
central (http://repo1.maven.org/maven2),
4thline.org-repo (http://4thline.org/m2),
jetty-releases (https://oss.sonatype.org/content/repositories/jetty-releases),
local1 (file:repo),
spring-snapshots (http://repo.spring.io/snapshot),
local2 (file:../repo),
maven2 (http://repo1.maven.org/maven2)Can everyone helps for this ?
Thanks a lot
