Enable Single Setting on All Users
Posted: 22 Sep 2015, 18:08
by TastyJams
Was wondering if there is a database query or something that I can run to enable a single setting for all existing users? For example, enabling the "Show Side Panel" option for all users?
Re: Enable Single Setting on All Users
Posted: 22 Sep 2015, 20:52
go to
db.view and excute this query to enable the SidePanel for all user
update USER_SETTINGS set SHOW_NOW_PLAYING=true
Posted: 22 Sep 2015, 21:37
by TastyJams
Thanks Mad! Your support has been great lately.
Is there somewhere I can find a list of settings I can modify with this type of command? That would be super helpful!
Posted: 22 Sep 2015, 21:44
you can display it with this query, but you should better change values only via GUI (for save use)!
Posted: 22 Sep 2015, 22:57
by TastyJams
Ah yes, thank you!
Last question on this topic... how do I run a query against a specific username? For example, changing "show side panel" for username "test"?
Posted: 22 Sep 2015, 23:38
update user_settings set SHOW_ARTIST_INFO=true where username='test'
