[Solved] Enable Chrome Notifications?
Mission accomplished!
TastyJams
Been thanked: 22 times
Unread post by TastyJams »
How do I enable the awesome Chrome Notifications that show up on the test server when starting a new track? Can't find the option anywhere in the settings. Build 7640
Re: Enable Chrome Notifications?
go to your personal settings and activate notification.
TastyJams
Re: [Solved] Enable Chrome Notifications?
Ah, there it is. Problem was that I was looking at Default User Settings and the option is not there. Option is also not there when editing other user's settings. Possible to add it?
These users thanked the author TastyJams for the post:
