[Solved] OSX Java
Mission accomplished!
skopo
Has thanked: 8 times
Been thanked: 16 times
[Solved] OSX Java
Unread post by skopo »
Hello
Does madsonic-6.0.7460 still run Java6 only on OS X?
These users thanked the author skopo for the post:
Re: OSX Java
Java 6 is more as outdated ;)
at least you must upgrade to Java7
EOL INFO: http://www.oracle.com/technetwork/java/ ... 35779.html
DOWNLOAD: http://www.oracle.com/technetwork/java/ ... 33155.html
skopo
Re: OSX Java
Madevil wrote:Hi there,
Fantastic
I installed Madsonic 6.0.7460 (native mac) to my test server OSX 10.10.5 with JRE8 and Madsonic doesn't start. No window, no serice nothing just nothing.
How to troubleshoot?
Re: OSX Java
if have recheck the installation with OSX 10.8.5 & JDK 1.8 and worked as aspected.
For troubleshooting look at the installation guides
http://beta.madsonic.org/pages/installation.jsp#mac
http://beta.madsonic.org/pages/installation.jsp#java
TYI: if you previously use Madsonic 5.1 on this MAC you have to cleanup this folder bellow before you start Madsonic 6.0
/Library/Application Support/Madsonic
skopo
Re: OSX Java
Yes!
Totally forget to clean this folder. Now works.
skopo
Re: OSX Java
Something is still wrong...
OSX versio is 10.10.5 and Java JRE is 1.8.0.60
UniversalJavaApplicationStub returns:
Applications/Madsonic.app/Contents/MacOS/universalJavaApplicationStub ; exit;
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/madsonic/booter/Main : Unsupported major.minor version 51.0
	at java.lang.ClassLoader.defineClassCond(ClassLoader.java:637)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
	at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
	at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
	at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
	at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
logout
[Process completed]
And Java -version shows:
java version "1.8.0_60"
Java(TM) SE Runtime Environment (build 1.8.0_60-b27)
Java HotSpot(TM) 64-Bit Server VM (build 25.60-b23, mixed mode)
No window, no service, nothing...
Re: [Solved] OSX Java
The error message means that you are using an older JAVA version,
i guess this is because your $JAVA_HOME environment isn't set right.
to check:
$ echo $JAVA_HOME
expected output:
/Library/Java/JavaVirtualMachines/jdk1.8.0_60.jdk/Contents/Home
to set this variable: In Mac OSX 10.5 or later, Apple recommends to set the $JAVA_HOME variable to /usr/libexec/java_home
nano .bash_profile
export JAVA_HOME=$(/usr/libexec/java_home)
source .bash_profile
echo $JAVA_HOME
or
echo export JAVA_HOME=$(/usr/libexec/java_home) > .bash_profile
https://support.apple.com/kb/dl1572?loc ... cale=de_DE
http://www.oracle.com/technetwork/java/ ... 33151.html
Hope this help you. :)
