[Solved] Problems with Default User Settings
Posted: 17 Sep 2015, 02:49
Server is 6.0.7450
It looks like the default user settings has issues depending on if the new user is created via the web interface or via LDAP.
I have default user settings:
Creating a new user (non LDAP) give these settings instead:
Not what I wanted. However, the default user settings are not changed.
With LDAP, and the exact same default user settings as above, I get this when a new user is created via LDAP:
And the default user settings are now:
Note the default user now has play files turned off, but alarmingly user is locked is now on. All users created from that point on are disabled until the default user settings are changed.
User is locked (Disabled)
User is administrator
X User is allowed to change settings and password
X User is allowed to play files
X User is allowed to use the search functions
User is allowed to play files in jukebox mode
X User is allowed to download files
X User is allowed to upload files
User is allowed to share files with anyone
User is allowed to change cover art and tags
User is allowed to create and edit comments and ratings
User is allowed to administrate Podcasts
X User is allowed to use Last.FM Feature Code: Select all
X User is allowed to create and edit comments and ratings
User is allowed to use Last.FM Feature With LDAP, and the exact same default user settings as above, I get this when a new user is created via LDAP:
X User is allowed to use Last.FM FeatureCode: Select all
X User is locked (Disabled)
