VERSION: MADSONIC 6.0 | BUILD: 7110.b9ea438.20150821.0127
SERVLET: jetty/8.y.z-SNAPSHOT
SERVER: CPU: E8400 | ARCH: X64 | MEMORY: 4GB
OS: Ubuntu 14.04.3 LTS
SYSTEM: SERVER
INSTALLER: DEB 20150821_madsonic-6.0.7110.deb
JAVA: OPEN JDK 1.7.0_79
BROWSER: CHROME 44 | FIREFOX 39 | SAFARI 9 | OTHER
CLIENT:
DESCRIPTION: Flash player button icon URLs don't respect context-path option.
REPRODUCIBLE: YES
The buttons are there and clickable, they just aren't visible because of the missing icons.
For instance, the link to the stop button is example.com/icons/buttonPlayer/black/stop.png, when it should be example.com/<context-path>/icons/buttonPlayer/black/stop.png
Navigated to https://example.com/madsonic/index.view
GET https://example.com/script/fontawesome/css/font-awesome.min.css
GET https://example.com/icons/default/panel.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/rewind2.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/rewind1.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/forward1.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/stop.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/forward2.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/clear1.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/shuffle.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/saveQueue.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/lock2.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/repeat_off.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/loadQueue.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/undo.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/save.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/follow_off.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/settings1.png 404 (Not Found)
GET https://example.com/icons/default/arrow-all.png 404 (Not Found)
GET https://example.com/icons/buttonPlayer/black/lock1.png 404 (Not Found)
