[Solved] Do built 6.0.7110 support app?
Mission accomplished!
chali
Has thanked: 18 times
Been thanked: 35 times
Unread post by chali »
Do build 6.0.7110 support apps?
(for movies)
/Regards
chali
Re: Do built 6.0.7110 support app?
Can say that it works to play movies in the android app 5.7
but its not possible to fast forward/back in a movie :-(
anyone got a solution for this? i tried mx-player vlc and bsplayer. in different ways (mv,hv.hw,hw+)
/Regards
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech »
I think that may have to do with the format of the movie file itself. I know I can't do this for AVI files, but it seems to work for M?V files.
This will properly work again, if we transcode videos generally to mpeg/mp4 streams.
External Players can't handle jump points with flv streams!
i am working on other possibilities to transcode and streaming.
http://beta.madsonic.org/pages/api.jsp#dash
chali
hi thank for replying =)
Just a question, If external player can't handle jump point in flv
why have it been possible to jump before? (earlier versions of madsonic & Subsonic)
same thing with the bitrate settings, before i could lower the bitrate setting in the app
and it still plays the movie in a lower quality. But this dont work any more, (don't think this have worked since Android changed the rights for apps)
One more question that's been bugging me for a long time, If i put the app in hls mode, the movie plays fine for exactly 10sec
and then the sound dies or the movie stops, why is this? ( really frustrating )
God to now you working on it =)
/Regards
