[SOLVED] Madsonic running, but unreachable
Posted: 18 Jul 2015, 14:19
Hi all,
I got a little problem with my madsonic instance.
It is configured by default, so it should be listening to the port 4040, which is the default port for madsonic (if I am right).
So, i start subsonic :
I tail the /var/madsonic/madsonic_sh.log to check if everything is ok, there is no error message, not even warnings. So everything seems ok.
I checked the processes, everything seems running :
Problem : when i try to reach the web interface ( http://madsonic-server-ip:4040 ), it fails (like my server was offline).
When i check the listening ports on my server, I can see there is no process listenign on port 4040... it looks like to be the reason of my problem :
Does anybody have an idea to fix it ??
Have a nice day !
EDIT : Problem solved. Seems like my server is a bit slow starting madsonic... it works now, but it took around half an hour to completely start madsonic !
/etc/init.d/madsonic restart
[....] Restarting Madsonic Daemon: madsonicStarted Madsonic [PID 3962, /var/madsonic/madsonic_sh.log]
. okI tail the /var/madsonic/madsonic_sh.log to check if everything is ok, there is no error message, not even warnings. So everything seems ok.
ps -ef | grep madsonic
root 4278 1 42 15:13 pts/1 00:00:24 java -Xms256m -Xmx512m -Dmadsonic.home=/var/madsonic -Dmadsonic.host=0.0.0.0 -Dmadsonic.port=4040 -Dmadsonic.httpsPort=0 -Dmadsonic.contextPath=/ -Dmadsonic.defaultMusicFolder=/var/media/artists -Dmadsonic.defaultUploadFolder=/var/media/incoming -Dmadsonic.defaultPodcastFolder=/var/media/podcast -Dmadsonic.defaultPlaylistImportFolder=/var/media/playlists/import -Dmadsonic.defaultPlaylistExportFolder=/var/media/playlists/export -Dmadsonic.defaultPlaylistBackupFolder=/var/media/playlists/backup -Duser.timezone= -Djava.awt.headless=true -verbose:gc -jar madsonic-booter.jarProblem : when i try to reach the web interface ( http://madsonic-server-ip:4040 ), it fails (like my server was offline).
netstat -lnte
Connexions Internet actives (seulement serveurs)
Proto Recv-Q Send-Q Adresse locale Adresse distante Etat User Inode
tcp 0 0 0.0.0.0:631 0.0.0.0:* LISTEN 0 6163
tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 0 8391
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 0 5994
tcp 0 0 127.0.0.1:8005 0.0.0.0:* LISTEN 111 14428
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 108 7858
tcp 0 0 127.0.0.1:8080 0.0.0.0:* LISTEN 112 13986
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 5992
tcp 0 0 0.0.0.0:51413 0.0.0.0:* LISTEN 110 8655
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 7902Does anybody have an idea to fix it ??
Have a nice day !
