Error Loading Player: Could not load player config
Posted: 20 Jun 2015, 05:38
by j3tblk
Does anyone know why my player looks like this:
Just started, only change was I ran a robo mirror back up of the madsonic directory. Any help would be most appreciated.
Re: Error Loading Player: Could not load player configuratio
Posted: 20 Jun 2015, 21:24
by gurutech
Try another browser, or try upgrading your Adobe Flash. Or try switching to the HTML5 player instead of the Flash player.
Posted: 20 Jun 2015, 21:48
by j3tblk
gurutech wrote:Try another browser, or try upgrading your Adobe Flash. Or try switching to the HTML5 player instead of the Flash player.
Tried all of the above before posting. & HTML 5 is for video only in this version.
Re: FIXED Error Loading Player: Could not load player config
Posted: 21 Jun 2015, 13:21
by j3tblk
I can't figure out the problem. Even new installs look like this in Chrome.
Any help would be appreciated.
I donated to madevil because when you get non-existent dev/community support, your skills only get better. -right?
Posted: 21 Jun 2015, 17:18
by DoCC
hoi !
some addtitional helping hands to serve the 08/15 users are always welcome.
but we work w/o PN ,,, issues should be discussed in public ; )
Posted: 03 Jul 2015, 04:51
by j3tblk
Bump. I'm willing to pay/donate for a fix or html5 for audio.
Posted: 07 Jul 2015, 04:44
by gurutech
Check to make sure you have the latest version of Adobe Flash, if you haven't already.
I've been getting prompted to update my Flash for a couple days now on many sites (including this one). Just updated now, and seems to have fixed the issue.
