I have my Madsonic client set up to download a bunch of songs over WiFi so that I can go into "offline mode" while I'm commuting to/from work and not use my cellular data.
The problem is that I cannot seem to create a playlist of the cached songs and save the playlist locally. Is there a way to do this, or can it be added to the next version of the client?
offline playlists
- Been thanked: 105 times
offline playlists
- These users thanked the author gurutech for the post (total 2):
- Madsonic • taylord1984
- Rating: 15.38%
- Has thanked: 6 times
- Been thanked: 6 times
Re: offline playlists
Maybe even a simple database for offline files or load random list from offline cache
