Madsonic 5.1.5140 & Java 1.7.0_75-b13 Raspberry Pi2 crashing
Posted: 24 Mar 2015, 01:49
by diablo2424
Hello, I have recently setup Madsonic v5.1.5140 along with Java 1.7.0_75-b13 running on my Raspberry Pi2 Model B (quad-core, 1GB of RAM, running newest Raspbian Debian-based Linux for ARMv7). After about a day or so of running, I notice that the Madsonic service has failed with an error within /var/madsonic/madsonic_sh.log pointing me to a Java failure with details in /usr/share/madsonic/hs_err_pid9742.log, which is attached.
After a reboot, everything runs fine for another day or so, then the same error comes back. This is where my expertise ends, and I am at a loss as to what to try to fix this. Does anyone have any ideas on what I can do to try to keep this from happening constantly? Or has anyone else experience this?
Re: Madsonic 5.1.5140 & Java 1.7.0_75-b13 Raspberry Pi2 cras
Posted: 08 Apr 2015, 17:09
by Larzon
I have Madsonic 5.2 running on a Raspberry Pi 2 without any issues. However I'm not using OpenJDK 1.7
Maybe you could try updating to Oracle Java 1.8 JRE
Here's my server information:
jetty/8.y.z-SNAPSHOT, java 1.8.0_33, Linux 3.18.9-v7+ (arm) (122.8 MB / 248.0 MB)
Posted: 29 Apr 2015, 02:04
I would recommend you to use the Oracle JAVA8 implementation,
it's more reliably than OpenJDK and has ARM HW Floating point support.
http://www.oracle.com/technetwork/java/ ... 87472.html
Click the download button of Java Platform (JDK) 8. Click to Accept License Agreement,
download
jdk-8u33-linux-arm-vfp-hflt.tar.gz for Linux ARM v6/v7 Hard Float ABI.
Log-in Raspberry Pi, enter the command to extract
jdk-8u33-linux-arm-vfp-hflt.tar.gz to /opt directory.
sudo tar zxvf jdk-8u33-linux-arm-vfp-hflt.tar.gz -C /opt
Set default java and javac to the new installed jdk8.
sudo update-alternatives --install /usr/bin/javac javac /opt/jdk1.8.0_33/bin/javac 1
sudo update-alternatives --install /usr/bin/java java /opt/jdk1.8.0_33/bin/java 1
sudo update-alternatives --config javac
After all, verify with the commands with -verion option.
Posted: 03 Jun 2015, 01:07
by sterlingdax
I was having the same problem, using the same java version, will give this a shot and report back, was very, very frustrating, crossing my fingers!
Posted: 03 Jun 2015, 02:07
by sterlingdax
For the record, the PI now ships with Oracle Java, after swapping back to it, I remember doing it the first time.
I'm too new to post links, but look on the Raspberry Pi site
Posted: 04 Jun 2015, 03:21
by diablo2424
Thank you for the guide Madevil, however, I tried this, and the server worked for a day or two, then back to the same 503 Service unavailable error.
Posted: 09 Jun 2015, 10:19
by addseo1115
Thanks for sharing.
Posted: 09 Jun 2015, 19:43
by diablo2424
You're welcome... since I have been unsuccessful at getting Madsonic to stay running for more than 24-48 hours, I have switched back to the newest version of Subsonic (5.2.1 (build 4428) – March 4, 2015) running Java 1.8.0_33 with the instructions included above from MadEvil, and it's been running great.
Hopefully once the next version of Madsonic comes out, I can switch back as I'm beginning to miss some of the features of Madsonic, that Subsonic doesn't have.
Posted: 15 Jun 2015, 09:41
by addseo1115
